To show the functionality in the logging and parameter frameworks we did a video. It shows how to use the Bitcraze virtual machine to add variables and parameters to the firmware and to flash it using the radio bootloader. It also shows how to visualize the log-data using the plotter and to modify parameters from the client.
While cutting the video we noticed that the temperature goes down when we touch the pressure sensor. Either we are more cold-blooded than we should be or there’s a bug in there somewhere…
Edit: Turns out it not a bug. After some discussions this morning (and testing) we arrived at the conclusion that the measurement was correct. The PCB get’s a bit warm when running/charging and a fingertip isn’t necessarily 37C.
typo in header: turtorial or tutorial?
Thanks ! that is a great tutorial !
I’ll add to that. Fantastic video, please keep them coming.
