We have started the migration to GitHub, as usual with this kind of things it is not as obvious as we had thought at first. We decided to start with the most active repos which is currently the PC client. In the process it will be renamed crazyflie-clients-python to show that it contains the python libs and it works on more than just PC (ie. raspbery pie at least).
The source code migration is a little challenge due to the very different way Git and Mercurial handle branches. Using git-remote-hg we could pull the mercurial repos in a newly created git repos and then push the interesting branches and tags to github. This seems to work quite well but the last things we would like to have is the possibility to pull changes made in git to mercurial so that we could keep the current mercurial as a read-only mirror. Internally some of us plan to still work with mercurial anyway using hg-git and the great TortoiseHG.
For migrating the issues from BitBucket to GitHub we forked this script to add some functionality. Aside from copying the title/text/comments, we also wanted to map the metadata from BitBucket to labels/milestones on GitHub. So the modified script first creates/sets the correct milestone on GitHub and then creates/sets the labels according to a JSON mapping of BitBucket metadata to GitHub labels. It supports mapping of kind, status, priority and component to zero or more labels. The modified script is available here. While doing tests we discovered that github was sending a mail for every single ticket and comment, a collateral damage was one of our mailbox that got 303 messages in a couple of minutes (the smartphone attached to the mailbox actually played notification tunes for hours…).
