For those of you out there that are new to flying drones the height is often the most difficult thing to control. One solution to that problem is our newly released Z-ranger deck that can precisely measure the distance to the ground. Using this information the drone itself can stabilize on a desired target high and therefore become much easier to control. The Crazyflie 2.0 will then behave similar to a hovercraft sweeping over the ground or climbing stairs which is a ton of fun. As an in-action example please check out the video below where a Crazyfie 2.0 with a Z-ranger e.g. follows a flight of stairs :-).
For information of how to activate the height hold mode have a look at the getting started guide
