After a couple of delays we are happy to announce the Crazyflie Bolt is now stocked and ready to ship out. For those of you that are new to the Bolt, it is basically a Crazyflie 2.1 control board, but built to fit a bigger package. We have blogged about it a couple of times before, so if you would like to catch up you can start from the first idea, to maturing and finally changing name from RZR to Bolt. Another way to describe the Bolt is: Crazyflie 2.1 + Big-quad deck in one which doesn’t hog any deck expansion pins. Thus combinations such as Bolt + Led-ring + Lighthouse-4 is now possible or e.g. Bolt + Flow v2 + LPS.
Keep in mind that the Bolt is an early access product so you will most likely have to dig in to the code to hard-code PID-tuning parameters etc. Also trowing a warning finger, heavier drones can be very dangerous so be sure to keep safe!
The Crazyflie Bolt is delivered as a stand alone control board. Frame, motors, propellers and battery needs to be added, for details check out the wiki. Unfortunately we don’t have a good reference kit to recommend at the moment. If you happen to have built a good one, please share.
