| OK, got it! |
Python client improvements
Hello everyone, this is Victor and I’ve spent another internship here at Bitcraze. You can read my blogpost from last year here https://www.bitcraze.io/2019/08/summer-internship/. I have learned a lot since last year so it has been fun to put my skills to test!
This summer I have spent my time on improving the cf-client. I’ve fixed a few bugs but mostly it has been about making small changes that improves overall functionality.
Some of the improvements that I’ve worked on:
  • Flight-control tab: Added logging of x and y-axis and changed the columns to more suitable groups. Also improved UI for assist mode.
  • Flashing dialog: Added support to flash both of the MCUs individually as well as choosing which one to flash (previously you could only flash the stm32 or both). Created an automatic firmware-release-downloader, so that you don’t have to download the files manually.
  • Log-config: Added grouping of log-configurations, that allows you to group the configs into categories. Also added small functionalities like double-click to add, remove configs etc.
  • Added sort-support for all list/tables.
  • Removed traces from Crazyflie 1.0 and support for x-mode, since it is no longer supported by the client.
  • Removed traces from python 2.
I hope that the functionalities will help you and make your experience with the client better. If you have any tips for further improvements, you’re more than welcome to leave a comment or contribute yourself. This is my last week for this summer, but I hope to see you all again and until then, fly safe!
