I have returned from my family visit in California, who I’ve haven’t seen them in 3 years due to Covid. To spend the most possible time with them, the plan was that I would still work full time for Bitcraze from my father’s home. The problem became however, that it wouldn’t fit so well in our current way of work as I would miss all the morning stand up meetings due to the large time difference between Sweden and California (-9 hours). That is why we settled that I would work on separate projects/investigations during my time away. So I thought it would be a great opportunity to dig into ROS and 3D simulations again and see what the latest state of that is! So about the simulations is what I’ll be mostly talking about right in this blog post, in terms of what simulators are out there and what simulation development is currently ongoing.
Need for simulation?
Why would it be actually be necessary to have a simulation in our current frame work? Just to give an example, my new colleague Jonas recently tried out his hand on the CFlib swarm class for the first time for the BAMdays tutorials, and simulator would have been great during that initial porcess. Namely, most of the crashes were not necessary due to low batteries or bad communication, but mostly due to the fact that he was not able to double check his script beforehand. If one is able to check if all the programmed positions of the Crazyflies are implemented as they should before an actual flight, this would prevented a lot of broken propellers!
Just to note here that there are a lot of types of simulations that you can think of. Earlier this year had our ex-interns Max and Josephine finish an Renode simulation of the Crazyflie’s microcontrollers. We’ve also seen the word Simulink pop-up multiple times on the forum which indicates that quite some control classes are investigating the dynamic model of the Crazyflie. However, the type of simulation that I’m currently referring to are the 3D simulators in which a robot or quadcopter can move and interact with a virtual environment, with usually an physics engine in effect.
Crazyflie in Gazebo (+ROS)
During some initial investigation there were already some simulations that pop out. First of all I went and looked into what is available for Gazebo at the moment, which is:
- CrazyS: https://github.com/gsilano/CrazyS (ROS Melodic and Gazebo 9)
- sim_cf: https://github.com/wuwushrek/sim_cf (ROS Kinetic and Gazebo 7)
CrazyS is based on the RotorS simulation with some additional off-board crazyflie controllers for position control. I wasn’t able to build it for my Ubuntu 20.04 just yet myself, but that there is ongoing work to port CrazyS to ROS Noetic. For now on a virtual machine with ROS melodic it build just fine! Note my laptop did had to work quite hard when I wanted to simulate more than 1 Crazyflie, but the physics and plugins that were made for Gazebo is enabling many to do a lot for their research. Please check out the core papers about CrazyS!
Sim_cf is perhaps a little lesser known, but the project does stand out as it has some interesting features to it. It is for instance, possible to use the actual c-based firmware in software-in-the-loop (SITL) mode, which controls the simulated Crazyflie. It is even possible to use an actual crazyflie with an hardware-in-the-loop (HITL) simulation. Eventhough the project is not actively maintained anymore, I did manage to build it from source for ROS Noetic and Gazebo 11, although I was not able to fly more than 4 do to errors.
Other Simulators
Ofcourse Gazebo is not the only possibility out there. I also had a quick go at another simulator called Webots, which is quite an interesting option indeed as well. Currently there is only one quadcopter model available, so it only makes sense for it to also contain an Crazyflie! They do use their own robotic format, so probably the easiest process would be, is to convert an existing model for Gazebo/ROS into an format that Webots can understand.
Also, quite recently, a trending tweet has brought us to the attention of a Rviz based Crazyflie simulation! This looks quite promising as well, so I will try this out quite soon too.
Ongoing work in Ignition Gazebo
So in the future, the current Gazebo in its form will disappear and will be only be part of Ignition. So that is why it made sense for me to start playing with an separate Crazyflie model and plugins for the Ignition frame work instead. Moreover, it seems that quite some elements and plugins based on the RotorS simulation for the original gazebo, are now fully integrated within the Ignition gazebo framework, which should make it more easier to make quadcopter models fly. Currently it’s still work in progress, so right now is only to be found on my personal github repository, but as soon as it becomes more fleshed out and stable, this will probably transferred to Bitcraze’s github repos and we will write a more elaborate blogpost about it. For now, I’ll try to work on it further as my Fun Friday project!
In the mean time, we have started a simulation discussion thread in the Crazyswarm2 repository, which is an ongoing port of Crazyswarm to ROS2. It would be the ideal situation if we would be able to use this simulator for both Crazyswarm and our native CFlib! But I’ve mostly have used Gazebo in the past, so if there are any other simulators that we should try out too, please join the discussion and let us know!
Hei,
great post! It’s good to see development in the direction of simulations. Just as a minor note: I guess your link behind “simulation discussion thread” is incorrect? :)
Thanks! and you’re right, so I’ve changed the link :)
I am wondering how easy would it be to sync sim_cf with the up to date firmware? SITL seems pretty useful for development.
Yes that would be indeed very handy, although it would be even better to perhaps integrate those changes into the official Crazyflie firmware… But the commits I saw that were necessary to build the firmware for this state seemed quite extensive and that is not something that we can easily merge in our current firmware.
There are perhaps other options that might be better. There are plans to integrate python bindings for the controller & estimator part of the firmware which might be a good strategy. Moreover, we also had a master student project about embedded arm simulation of the firmware which would be even better. Anyway, we need to focus on the options and see what is the best approach and also the most future proof.
Hi Kimberly,
Thanks for sharing your post. I just wanted to share that I have been lately working on a simulation environment for the CrazyFlie drone, too, using PyBullet as physics engine: https://github.com/SvenGronauer/phoenix-drone-simulation
I also tested transfers from the simulator to a real-word CrazyFlie with Reinforcement Learning which worked quite well.
Best,
Sven
Ah thanks for sharing! I’ve heard of another simulator as well that uses pybullet too by University of Toronto: https://github.com/utiasDSL/gym-pybullet-drones. Seems that it is popular!
I’ll start a discussion thread in the https://github.com/bitcraze/crazyflie-simulation discussion tab to list some existing simulators, and I’ll add yours too. Perhaps there you can share your experiences with it?
How did you build sim_cf: https://github.com/wuwushrek/sim_cf to noetic? I am facing many problems. Thank you.
Oh my that’s a while ago, and I don’t have ROS1 on my current computer. I believe I just started from the source and did catkin make and googled every error I got :)
