One of the great features of the stock Crazyflie 2.1 is that it is more or less harmless. The Crazyflie 2.1 brushless weighs roughly the same but has almost twice the amount of thrust force, so a little bit of more care is needed. We therefore decided to provide optional propeller guards. While propeller guards adds safety they also add weight and disrupt the air flow from the propellers. Adding to that, the weight is located far from the center which increases the inertia even further, resulting in a less agile drone. For some applications this is not a problem but for others it is, this is why we are making them optional, meaning they are easy to replace with simple landing legs by utilizing a snap-on fitting.
The design is not fully finalized yet but we are getting close, voilá!
If the design goes according to plan they will also withstand some bumping against walls which will be a very nice feature for many applications.
Further the landing legs and propeller guards are designed in a way so they will detach during high force impacts to prevent the PCB arms from breaking.
Awesome! Do you already have a release date? I can’t wait to get mine!
Thanks! We really hope we can release it during the fall of 2024
It would be nice to see some real drop-tests :)
