Testing the Himax camera on the AIdeck
This concerns the example in folder AIdeck_examples/GAP8/test_functionalities/test_camera/. This was tested on GAP_SDK version 3.8.1.
In the makefile enable APP_CFLAGS += -DASYNC_CAPTURE
if you want to test the asynchronous camera capture and remove it if you want to test the normal one. To save a color image enable APP_CFLAGS += -DCOLOR_IMAGE
. And, to capture a 324x324
image enable APP_CFLAGS += -DQVGA_MODE
. Please note though that capturing an image in non-QVGA mode might not always work correctly.
To test out the code, first, source the AIdeck config (configs/ai_deck.sh) in your terminal and write
make clean all run io=host
for onram flashing with your programmer.
Run in Docker
To build and execute in the docker we need to place the demosaicking
-files in the common
-folder inside the docker.
docker run --rm -it -v $PWD:/module/data/ --device /dev/ttyUSB0 --privileged -P gapsdk:3.7 /bin/bash -c 'export GAPY_OPENOCD_CABLE=interface/ftdi/olimex-arm-usb-tiny-h.cfg; source /gap_sdk/configs/ai_deck.sh; cd /module/data/; make clean all run'
