In this example, a binary classification CNN (object or background) is trained and executed on the AI-deck. The models included in the example are trained on data from a very specific domain (a table in the Bitcraze arena with a particular Christmas package) with limited data augmentation, resulting in poor generalization and low robustness. For good results in your own domain, the example can be trained on a custom dataset captured by the AI-deck camera and tailored to detect multiple custom classes of your choosing. The training can currently only be performed on a native installation. Execution on or flashing the AI-deck can be done with either a native installation or the GAP8 Docker environment.
The CNN used in this example is a pre-trained MobileNetV2 (alpha = 0.35, image input size = 96x96x3) with a custom classification head and additional convolutional layers to process the grayscale/Bayer camera stream from the AI-deck. These layers resize the input to match MobileNet’s expected input shape. The example was tested on an AI-deck v1.1 equipped with a Bayer color camera.
CNN fine-tuning demo based on TensorFlow “retrain classification” demo.
For more information on good deep learning practices, we recommend reviewing Deep Learning by Goodfellow, Bengio and Courville, available online for free.
File structure
root(classification)
contains everything required to (re)train a custom MobileNetV2, and export to a TensorFlow Lite model. It also contains the project to deploy the generated TensorFlow Lite model on the AI-deck.
model/
contains the generated TensorFlow Lite models, and nntool
scripts.
training_data/
should contain all training/validation images, the TensorFlow training pipeline expects a file structure as included, with separate folders for each class in both a train and validation directory.
samples/
should contains sample images used by nntool
to quantize the imported models (optional, only required if MODEL_PREQUANTIZED = false in Makefile). These can be taken from the dataset.
Prerequisites
Build Environments
TensorFlow
You can choose between two approaches for setting up the TensorFlow environment, depending on your preference:
- Native Installation
Set up a separate Python environment with the required dependencies. We recommend using a virtual environment manager such as Miniconda or Penv. Ensure you are using Python version 3.10 and install the required packages using pip:pip install -r requirements.txt
- Docker Container (recommended for this documentation)
Alternatively, you can use Docker to handle the TensorFlow environment. This documentation uses Docker for the TensorFlow training steps.
GAP8
Similarly, there are two ways to set up the GAP8 environment:
Native Installation
Install thegap_sdk
natively on your machine (>= 4.22.0). -
You can also use Docker to build the GAP8 application. This documentation assumes the use of Docker for compiling the GAP8 examples.
Select your model
Option 1: Fine-tune model with your custom dataset (recommended)
Collect data
Collect images from the AI-deck using the WiFi streamer example with the opencv-viewer
script (use the --save
flag). Place them in the training_data
folder according to the instructions inside. The captured data must be split into a training and validation set manually (a good starting point is a 75% train, 25% validation split). You can rename the existing classes as needed. If you have more than two classes, be sure to adjust the number of units in the final (dense) layer of the model.
The folder structure should look like this:
/train/class_1/*.jpeg
/train/class_2/*.jpeg
/validation/class_1/*.jpeg
/validation/class_2/*.jpeg
Fine-tune the network with your custom dataset
To fine-tune the model, run the following command from the aideck-gap8-examples/examples/ai/classification/
directory:
For Docker:
docker run -it --rm -v $PWD:/tmp -w /tmp tensorflow/tensorflow:2.17.0 examples/ai/classification/docker_train_classifier.sh
For Native Installation:
python train_classifier.py [--args]
Possible Arguments for train_classifier.py
The following arguments can be passed to customize the training process:
--epochs
: Number of training epochs (default: 20)--finetune_epochs
: Number of fine-tuning epochs (default: 20)--dataset_path
: Path to the dataset (default:"training_data"
)--batch_size
: Batch size for training (default: 8)--image_width
: Width of input images (default: 324)--image_height
: Height of input images (default: 244)--image_channels
: Number of input image channels (default: 1)
Example usage for native installation:
python train_classifier.py --epochs 30 --batch_size 16 --dataset_path custom_data
For Docker, to use these arguments, you need to manually edit the docker_train_classifier.sh
script where train_classifier.py
is called. Add the arguments directly in the script like above.
The training process will automatically generate quantized and non-quantized TensorFlow Lite models, which will be placed in the model/
directory.
Option 2: Use our pre-trained model
To use our pre-trained models, trained on the Bitcraze flight arena + a Christmas package, extract classification.tflite
and classification_q.tflite
from classification_tflite_files.zip
into the model/
directory.
Deploy on the AI-deck
Option 1: Flash the image classification CNN to the AI-deck (recommended)
After successfully completing all previous steps, you can now run the classification CNN on the AI-deck. From a terminal with the docker container, or gap_sdk dev environment, in the aideck-gap8-examples/
folder, execute:
$ docker run --rm -v ${PWD}:/module aideck-with-autotiler tools/build/make-example examples/ai/classification clean model build image
Then from another terminal (outside of the container), use the cfloader to flash the example if you have the gap8 bootloader flashed AIdeck. Change the [CRAZYFLIE URI] with your crazyflie URI like radio://0/40/2M/E7E7E7E703
cfloader flash examples/ai/classification/BUILD/GAP8_V2/GCC_RISCV_FREERTOS/target.board.devices.flash.img deck-bcAI:gap8-fw -w radio://0/90/2M/E7E7E7E7E7
When the example is flashing, you should see the GAP8 LED blink fast, which is the bootloader. The example itself can be noticed by a slow blinking LED. You should also receive the classification output in the cfclient console.
Option 2: Run the image classification CNN on the AI-deck over JTAG
After successfully completing all previous steps, you can now run the classification CNN on the AI-deck. However, as you want to run it with the debugger connected, you need to adapt the following parts of the code:
- this will overwrite the bootloader, adopt the Makefile accordingly by removing
-DFS_PARTITIONTABLE_OFFSET
- if you want the output in the terminal and not over UART, uncomment io=host and comment io=uart in the Makefile
- instead of via CPX you want to write with printf, which will then be forwarded either to the terminal or UART (e.g. in cpxPrintToConsole add printf(fmt);)
- note that you might not be able to properly communicate with the NINA module if you don’t restart it as well
folder, execute:
Then you need to write the weights and run the CNN:
docker run --rm -v ${PWD}:/module --privileged aideck-with-autotiler tools/build/make-example examples/ai/classification all run
You should now see the same output as in the gif in the beginning.
