Userguide cfclient GUI
This page uses the terms roll/pitch/yaw extensively. For that to make any sense for a quadcopter we need to know where the front is, so you will need to know Crazyflie’s coordinate system
How to get flying with a controller
  • Start up the application
  • Press Scan
  • When the handshake is done you can start flying the Crazyflie. Remember the most tricky part is the thrust so start out easy...
For more info on LED indicators etc. have a look at the Crazyflie 2.X user guide.
Main UI
CF client main
    • Address: The address to scan for. If you didn’t change this in the configuration, then leave the default of 0xE7E7E7E7E7
  5. The selected and used input interface
Tabs and toolboxes
The main interface is built up of different tabs that can be shown/hidden from the View->Tabs menu. The tabs can also be used as toolboxes, that is small windows that can be docked to the sides of the main window. This makes it possible to display multiple windows at the same time, the console log can for instance be visible as a toolbox at the same time as the parameter tab is open to set a value. To open a toolbox, use the View->Toolboxes menu, if the toolbox is already open as a tab, the tab will be removed and it will be opened as a toolbox instead.
The following tabs/toolboxes are currently available:
Functionality
Firmware upgrade
For updating the Crazyflie firmware you can keep being connected to the crazyflie. This will open up a separate dialog that will guide you through the process.
Please note that you need to use a Crazyradio dongle to connect to the Crazyflie when doing firmware upgrades. Upgrading using USB is not possible.
Deck firmware
Some decks have a CPUs or other chips that runs firmware that needs to be updated from time to time as well. The Crazyflie firmware verifies that it is compatible with the deck firmware during start up. If the firmware in a deck that is installed needs to be upgraded this will be logged in the console log. Deck firmware is upgraded as a part of the Crazyflie firmware upgrade process, just make sure the deck is mounted when you run the upgrade.
CFclient bootloading
To update the firmware in the Crazyflie 2.X do the following:
  • Make sure to have any decks you will be using attached during the update, since some of the decks contain their own firmware which will also be updated during the firmware update. Also make sure there is a battery attached.
  • Go to the menu Connect->Bootloader
  • Connect to the crazyflie in this dialog, if it is not already connected in the flighttab.
  • Chose what to flash
    • Use the “From release” tab to automatically use an official release. Make sure to select the right platform (cf2 is the Crazyflie 2.X)
    • Use the “From file” tab if you have some other release file you want to flash.
  • Click "Program" and wait for both the STM, NRF and decks to be flashed. Note: the Crazyflie may restart multiple times during this process.
  • Your crazyflie will automatically restart a couple of times.
  • Do not touch or restart your crazyflie untill all flashing is done and you see "status: idle" at the bottom.
  • To check the firmware version, under the View menu, open up Tabs->Console tab and look at the output when connecting to the Crazyflie 2.X.
If you accidently restarted your crazyflie during flashing or anything else happend which caused your crazyflie to not start up properly, follow the instructions for recovery mode.
Firmware configuration
It is possible to set another channel to communicate with the Crazyflie 2.X. It can be wise to do this if there exist other wireless networks that can interfere, especially WiFi. It is also possible to permanently store the trim values for pitch and roll.
  • Radio channel Can be set to anything between 0 and 125, correspond to a frequency from 2400MHz to 2525MHz. In most countries channel 0 to 80 is OK to use but this should be checked with you local regulations. If using 2M datarate, the copter channels should be 2 apart (2MHz).
First connect to the Crazyflie 2.X with the normal connect button. Then open “Connect->Configure 2.X” to reach the configure 2.X dialog
CF2 config
Once the settings has been made press the write button to save them permanently in the Crazyflie 2.X EEPROM. Then restart the Crazyflie and connect to the new address.
Logging
The Crazyflie logging framework allows to log the state of Crazyflie variables in real-time. This subsystem is used by the client to show information like pose or battery level.
The list of log variable can be seen in the "log TOC" tab in the client.
Variables are logged in block: one log block is a list of variable that are logged at the same time. You can setup custom log blocks that can be plotted in the plotter and saved to file in the log block tab.
To setup a new log block click on the menu "settings/logging configuration", You then see the following toolbox:
cfclient logging configuration
  1. List of log variable in the Crazyflie
  2. Log variables in the current log block
  3. Add the selected Crazyflie log variable in the log block
  4. Remove the selected log block variable from the log block
  5. Period at which the variables are sampled and the block is send by the Crazyflie to the client. The minimum possible period is 10ms (100Hz) and it can be set by step of 10ms up to 2550ms.
  6. Bytes used by the variables in the log block.
  7. File-tree structure where you can sort the log-blocks into categories.
  8. Create/delete a category or a log-configuration. This can also be done by right-clicking anywhere in the category-tree.
  9. Save log block configuration
Flight settings
Input devices
Creating new mappings
The software comes bundled with mappings for Xbox and PS3/4 controllers, but if you have another input-device then it's quick to create your own configuration. Go to the menu Input device -> Configure device mapping.
cfclient configure device
cfclient configure device axis
cfclient configure device detect
Follow the instructions to detect the axis or button that you would like to map to the functionality. If you would like to map the functionality to two axis (like right/left shoulder-button) then select Combined axis detection and follow the instructions.
cfclient configure device feedback
Selecting device
The Input device menu contains a number of different "modes" that can be used for controlling a Crazyflie. Currently there's thee to choose from. The alternatives will only be enabled if there's enough input devices connected to use them.
cfclient devices normal
cfclient devices mux select
cfclient input teacher
cfclient input student
cfclient input mux configured
ZMQ backends
The benefit of using this approach instead of the stand-alone ZMQ server is that you will not have to take care of everything, just the parts you are interested in for the moment.
