The Crazyflie Python client runs a number of back-ends where you can set/get information from other applications via ZMQ.
Here's a list of the ports/functions available:
Port | Type | Functionality |
1213 | REQ | Set parameters |
1214 | PUSH | LED-ring memory |
1212 | PULL | Input device |
By default all sockets are disabled in the configuration file and needs to be enabled. The configuration file parameter are named enable_zmq_param, enable_zmq_led and enable_zmq_input. see the configuration documentation for more information about the configuration file.
Parameters
The parameter back-end gives access to setting parameters in the Crazyflie. The back-end is enabled by default.
Protocol
Available fields:
Field | Format | Comments |
version | int | Should be set to 1 |
cmd | string | Command to send (currently only set is supported) |
name | string | The name of the parameter |
value | string | The value of the parameter |
Example of setting the buzzer.freq parameter to 4000.
"version": 1,
"cmd": "set",
"name" : "buzzer.freq",
"value": "4000"
LED-ring
The LED-ring back-end gives access to the LED-ring memory driver where the user can write the RGB values for all 12 LEDs on the ring. The back-end is enabled by default.
Protocol
Available fields:
rgbleds | array of 3 item arrays of int | R/G/B value for each LED (starting at 1) |
Example of setting all LEDs off:
"version": 1,
"rgbleds": [
[0, 0, 0],
[0, 0, 0],
[0, 0, 0],
[0, 0, 0],
[0, 0, 0],
[0, 0, 0],
[0, 0, 0],
[0, 0, 0],
[0, 0, 0],
[0, 0, 0],
[0, 0, 0],
[0, 0, 0]
Input device
If you don't want to use the API and you don't want to bother about scanning/connecting/logging/etc or there's no API for the environment you use, there's an easy way to control the Crazyflie. Just like you would control the Crazyflie with a gamepad or joystick connected to a computer, you can use ZMQ to inject control set-points directly into the client. You still use the client for connecting/logging/graphing/setting parameters, it's just the control part that's broken out.
To enable controlling by the back-end select the ZMQ\@127.0.0.1:1212 input device in the Input device menu.
Protocol
Available fields:
client_name | string | Name of the client (currently unused) |
ctrl | dict | A dictionary with keys and values that match the internal names of controls in the client (see list below) |
Available keys for the ctrl dictionary:
Field | Range | Unit | Comments |
roll | N/A | degrees | |
pitch | N/A | degrees | |
yaw | N/A | degrees/second | |
thrust | 0-100 | Percent | |
estop | T/F | boolean | Used to stop the Crazyflie and disable the control |
alt1 | T/F | boolean | Alt1 is internally mapped to functionality like switching LED-ring effect |
alt2 | T/F | boolean | Alt2 is internally mapped to functionality like switching LED-ring headlights on/off |
Example:
"version": 1,
"client_name": "ZMQ client",
"ctrl": {
"roll": 0.0,
"pitch": 0.0,
"yaw": 0.0,
"thrust": 0.0
NOTE1: Altitude hold is currently not working.
NOTE2: The values are used at 100Hz in the client, no matter at what rate they are sent via ZMQ
