We have tested with 4 lighthouse base stations, which cover around 8x8x3 meters of flying space. It is possible to add more base stations to cover larger flying spaces. The firmware is compile with support for 4 base stations by default, but should be able to work with up to 16. This guide will outline the necessary steps to set up a larger system. Please first consult the “Getting started with the Lighthouse system” guide on our web to get a good understanding of basic use.
- Make sure that all base stations have a unique channel like 1, 2, 3, 4, 5 and so on. Use the “Set BS channel” button in the Lighthouse tab in the python client for this task
- In placement of the LH base stations, make sure that they must overlap, but avoid too many in one spot. The lighthouse deck can not handle more than 4 visible at the same time.
- Re-flash the Crazyflie with support for more base stations. Run
make menuconfig
and go to theExpansion deck configuration
menu and setMax number of base stations
to the desired value. Note: more base stations use more RAM. Build the code and flash it to the Crazyflie, see the documentation in this repo for instructions on building and flashing
