This howto is going to describe step-by-step how to make and flash your first Crazyflie 2.X deck driver. See the deck api documentation page for more information about the code.
Development environment
Writing the driver
Deck drivers are in the src/deck/drivers/src folder. Create this file named hello.c in the src/deck/drivers/src folder:
#include "debug.h"
#include "deck.h"
static void helloInit()
DEBUG_PRINT("Hello Crazyflie 2.1 deck world!\n");
static bool helloTest()
DEBUG_PRINT("Hello test passed!\n");
return true;
.name = "myHello",
.init = helloInit,
.test = helloTest,
DECK_DRIVER(helloDriver);
Adding the driver to the build
Add this to the Kbuild
file in src/deck/drivers/src/
obj-y += hello.o
Enabling the driver
Decks can have a memory that contains its name. In our case the hello
driver would be initialized only when a deck identified as "myHello"
is installed on the Crazyflie. For development purpose it is possible to
force enabling a deck driver with a compile flag. To do so set the
CONFIG_DECK_FORCE
config option to "myHello"
in your .config
either
by hand or using make menuconfig
CONFIG_DEBUG=y
allows to get more information from the Crazyflie console when
it starts. Debug should not be enabled if you intend to fly the
Crazyflie out of the lab (it disables the watchdog).
Note Each time you modify your .config
you
should recompile the full firmware by cleaning up the build folder with
'make clean'
Compile, flash and run!
crazyflie-firmware$ make clean && make
If you see
*** Configuration file ".config" not found!
, make sure select the right build config. Please see the build instructions
CC hello.o
Build for the CF2 platform!
Build 22:f8243162f727 (2020.04 +22) MODIFIED
Version extracted from git
Crazyloader build!
Flash | 218132/1032192 (21%), 814060 free | text: 213024, data: 5108, ccmdata: 0
RAM | 71564/131072 (55%), 59508 free | bss: 66456, data: 5108
CCM | 43528/65536 (66%), 22008 free | ccmbss: 43528, ccmdata: 0
../crazyflie-clients-python/bin/cfloader flash cf2.bin stm32-fw
10 seconds ...
done!
Connected to bootloader on Crazyflie 2.0 (version=0x10)
Target info: nrf51 (0xFE)
Target info: stm32 (0xFF)
Flashing 1 of 1 to stm32 (fw): 161867 bytes (159 pages) ..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10.........9
Reset in firmware mode ...
