Dependency tool
There is a tool that can be used to visualize and analyze dependencies in the source file tree. the code for the tool is located in tools/dependency and is called by running the deps.py file.
The tool extracts subsets of the full file tree, based on user input, and either visualize the subset, or count the number of files.
The tool uses information from the source files, but also from intermediate files generated by kbuild, for that reason valid results will only be available after a successful build. The results are based on the current build configuration, for instance created by make menuconfig. Remember to run make before using the tool.
In visualizations, c-files are shown as triangles and h-files as circles. The color is based on the first part of the path. Hovering over a file shows the full path. A node with dependencies can be highlighted by clicking it, and it can be moved by dragging.
Example uses
Visualize dependencies of commander.c
Use the -d flag for finding dependencies and the -v for visualizing the result.
./tools/dependency/deps.py -d -v src/modules/src/commander.c
The tool will first try to find the full target (src/modules/src/commander.c in this case) in the file tree, if not found, it will try to find the target in the file names. This makes it possible to do ./tools/dependency/deps.py -d -v commander.c instead. Note: it there would exist two commander.c files in the file tree, at different paths, both of them would be included.
It is possible to limit the number of levels of dependencies to search for using the -l flag. To only show one level of dependencies, use ./tools/dependency/deps.py -d -l 1 -v commander.c
Visualize all files that include deck.h
Use the -u to find the files that is using a file.
./tools/dependency/deps.py -u -v cpx.h
Visualize multiple targets
More than one target can be used ./tools/dependency/deps.py -d -l 1 -v commander.c cpx.c will show first level dependencies to commander.c and cpx.c
It is also possible to use regex for targets. If the target does not match a full path, or a file name, the tool will try to interpret it as a regex. For instance, to show all files in src/hal/interface/, use ./tools/dependency/deps.py -v src/hal/interface/.*
Visualizing dependencies from one location to another
Use the -f flag. The first target is the “from” location and the rest is the “to” location. To visualize dependencies from /src/platform to /src/utils, use ./tools/dependency/deps.py -f -v src/platform/.* src/utils/.*
To show dependencies form a directory to “all other directories”, you can use regex. The following essentially means find dependencies from “platform” to “anything but platform”: ./tools/dependency/deps.py -f -v src/platform/.* '^src/(?!platform/).*$'
Count files
The -t flag prints the total number of files found, ./tools/dependency/deps.py -d -t src/modules/src/commander.c. -cc counts the number of c-files and -hh counts the number of h-files.
The -z flag returns a non-zero result (fail) if the total file count is not zero. This is useful in build tools to make sure there are no “backwards” dependencies. For instance, if we want to make sure files in src/utils do not have dependencies to files outside src/utils, use ./tools/dependency/deps.py -f -z src/utils/.* '^src/(?!utils/).*$'
