Deck memory format
The OneWire (OW) memory contained in all Crazyflie 2.x decks is used to detect the boards connected in order to:
  • Decide if it is safe to start the system.
  • When the system is started, initialize the required drivers for the deck installed.
  • The header is 7 bytes long and contains the identity of the board encoded in VID/PID (Vendor ID and Product ID) as well as a bitfield describing the pins the deck is driving (to avoid conflict).
  • The key/value area is extendable and contains more information like the deck name, board revision and driver-specific information (ie. for configuration or calibration for example).
Content
  1. Header     1 Byte 0xEB
  2. UsedPins       4 Bytes
  3. VID        1 Byte
  4. PID        1 Byte
  5. crc        1 Byte CRC32[0] (LSB byte) from 1 to 4.
  6. Version        1Byte, 0 for now
  7. DataLength     1 Byte (255 max data length…)
  8. key/value data <DataLength> bytes
  9. crc        1 Byte CRC32[0] (LSB byte) from 6 to 8
  • The header area is from 1 to 5.
  • The key/value area is from 6 do 9
Drive PC11 PC10 PB7 PB6 PB8 PB5 PB4 PC12 PA2 PA3 PA5 PA6 PA7 P0.11 P0.12 P0.08
Low 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
High 16 17 18 19 20 21 22 23 24 25 26 27 28 29 31 31
For example is a deck has a GPS that has its UART TX on PC11 (push-pull, drives high and low), the UsedPins value will be (1<<0) | (1<<16) = 0x00010001. As another example is a deck has an I2C sensor on PB6,PB7 (Open collector, only drives low), the UsedPins value is then: (1<<2) | (1<<3) = 0x0000000C
Key/value area
Elements have this format:
Id 1Byte
length 1Byte
data <length> Bytes
Element Element_id Data type Note
boardName 1 string Short. Starts by “bc” for Bitcraze boards
revision 2 string
customData 3 binary Data understood by the deck driver
Example
0000000: eb 00 00 00 00 bc 01 44 00 0e 01 09 62 63 4c 65  .......D....bcLe
0000010: 64 52 69 6e 67 02 01 62 55                       dRing..bU
Content:
    "header": {
        "usedPin": 0,
        "vid": 188,
        "pid": 1
    "data": {
        "boardName": "bcLedRing",
        "revision": "b"
Element IDs and types (DTD):
    "boardName": {
        "type": "string",
        "id": 1
    "revision": {
        "type": "string",
        "id": 2
    "customData": {
        "type": "binary",
        "id": 3
