LED-ring on Crazyflie 2.1 Brushless
How to get the LED-ring working on Crazyflie 2.1 Brushless
Due to a resource conflict between the DSHOT motor signal driver and the LED-ring (they both use DMA1 Stream 6), DSHOT can not be used together with the LED-ring. The default ESC firmware we use is Bluejay (a successor of BLHeli_S) which has removed support for all other motor signal protocols than DSHOT. A work-around then is to use BLHeli_S and e.g. OneShot125 protocol. However there are more complications as a 24KHz ESC PWM seem to interfere with the gyro, so a special version of BLHeli_S that supports 48KHz should be used. This version is called BLHeli_M.
Download the BLHeli_M O_H_10_48_REV16_77.hex
The ESC firmware file O_H_10_48_REV16_77.hex can be found here. Download it to a local folder.
Flash the ESCs
Use the ESC-configuration guide to flash custom FW to the ESCs
Flash custom FW
Write settings to the ESCs
We recommend the settings in the picture below:
BLHeli_M recommended settings
To write the setting to the ESCs press the “Write settings” button. This will write all the settings shown in the GUI to the ESCs.
NOTE if you push “reset to default” these settigns are not our default settings, but the ones specified by the esc-configurator website.
Configure the Crazyflie 2.1 brushless firmware to output OneShot125/Oneshot42 motor signal
Use the build and flash firmware guide to learn how to build and flash firmware
Build the firmware with OneShot125/OneShot42 motor signal protocol:
$ make cf21bl_defconfig
$ make menuconfig
Flash custom FW
Then build and flash the Crazyflie 2.1 Brushless firmware. The LED-ring should now work with your Crazyflie 2.1 Brushless.
Restoring the original ESC firmware
We use different settings then the official Bluejay firmware, so use our fork of the Bluejay ESC firmware. Our latest release can be found here. Download and flash the cfbl2.1_esc_normal_m1-m3.hex on all ESCs. You can configure the rotation direction afterwards together with the other settings that are shown in the ESC-configuration guide.
