Here we will go through step-by-step how to make your crazyflie move based on a motion script. For the first part of this tutorial, you just need the crazyflie and the flow deck. For the second part, it would be handy to have the multiranger present.
Prerequisites
We will assume that you already know this before you start with the tutorial:
- Some basic experience with python
- Followed the crazyflie getting started guide and the connecting, logging and parameters tutorial.
Get the script started
Since you should have installed cflib in the previous step by step tutorial, you are all ready to got now. Open up an new python script called motion_flying.py. First you will start by adding the following import to the script:
import logging
import sys
import time
from threading import Event
import cflib.crtp
from cflib.crazyflie.log import LogConfig
from cflib.crazyflie.syncCrazyflie import SyncCrazyflie
from cflib.positioning.motion_commander import MotionCommander
from cflib.utils import uri_helper
URI = uri_helper.uri_from_env(default='radio://0/80/2M/E7E7E7E7E7')
DEFAULT_HEIGHT = 0.5
BOX_LIMIT = 0.5
if __name__ == '__main__':
cflib.crtp.init_drivers()
with SyncCrazyflie(URI, cf=Crazyflie(rw_cache='./cache')) as scf:
This probably all looks pretty familiar, except for one thing line, namely:
This imports the motion commander, which is pretty much a wrapper around the position setpoint frame work of the crazyflie. You probably have unknowingly experienced this a when trying out the assist modes in this tutorial with the flow deck in the cfclient
Step 1: Security before flying
Since this tutorial won’t be a table top tutorial like last time, but an actual flying one, we need to put some securities in place. The flow deck that you are using, should be correctly attached to the crazyflie. If it is not, it will try to fly anyway without a good position estimate and for sure is going to crash.
We want to know if the deck is correctly attached before flying, therefore we will add a callback for the "deck.bcFlow2" parameter. Add the following line after the ...SyncCrazyflie(...) in __main__
scf.cf.param.add_update_callback(group="deck", name="bcFlow2",
cb=param_deck_flow)
time.sleep(1)
Above __main__, start a parameter callback function:
def param_deck_flow(_, value_str):
value = int(value_str)
print(value)
if value:
deck_attached_event.set()
print('Deck is attached!')
else:
print('Deck is NOT attached!')
The deck_attached_event is a global variable which should be defined under URI. Note that the value type that the param_deck_flow() is a string type, so you will need to convert it to a number first before you can do any operations with it.
deck_attached_event = Event()
Try to run the script now, and try to see if it is able to detect that the flow deck, is correctly attached. Also try to remove it to see if it can detect it missing as well.
Note: You can use a different positioning system and deck if you’d like, but you’ve got to look at a different parameter than “deck.bcFlow2”. Check out other options in the parameter list.
This is the full script as we are:
import logging
import sys
import time
import cflib.crtp
logging.basicConfig(level=logging.ERROR)
print(value)
if value:
else:
scf.cf.param.add_update_callback(group='deck', name='bcFlow2',
cb=param_deck_flow)
time.sleep(1)
Step 2: Take off function
So now we are going to start up the SyncCrazyflie and start a function in the __main__ function:
if not deck_attached_event.wait(timeout=5):
print('No flow deck detected!')
sys.exit(1)
# Arm the Crazyflie
scf.cf.platform.send_arming_request(True)
time.sleep(1.0)
take_off_simple(scf)
See that we are now using deck_attached_event.wait()? If this returns false, the function will not be called and the crazyflie will not take off.
Now make the function take_off_simple(..) above __main__, which will contain the motion commander instance.
def take_off_simple(scf):
with MotionCommander(scf, default_height=DEFAULT_HEIGHT) as mc:
time.sleep(3)
mc.stop()
If you run the python script, you will see the crazyflie connect and immediately take off. After flying for 3 seconds it will land again.
The reason for the crazyflie to immediately take off, is that the motion commander if intialized with a take off function that will already start sending position setpoints to the crazyflie. Once the script goes out of the instance, the motion commander instance will close with a land function.
Changing the height
Currently the motion commander had 0.3 meters height as default but this can of course be changed.
Change the following line in take_off_simple(...):
with MotionCommander(scf) as mc:
mc.up(0.3)
time.sleep(3)
mc.stop()
Run the script again. The crazyflie will first take off to 0.3 meters and then goes up for another 0.3 meters.
The same can be achieved by adjusting the default_height of the motion_commander, which is what we will do for now on in this tutorial. Remove the mc.up(0.3) and replace the motion commander line with
with MotionCommander(scf, default_height = DEFAULT_HEIGHT) as mc:
Add the variable underneath URI:
Double check if your script is the same as beneath and run it again to check
import logging
import sys
import time
import cflib.crtp
time.sleep(3)
mc.stop()
def param_deck_flow(name, value_str):
cb=param_deck_flow)
time.sleep(1)
sys.exit(1)
# Arm the Crazyflie
time.sleep(1.0)
Step 3 Go Forward, Turn and Go back
So now we know how to take off, so the second step is to move in a direction! Start a new function above def take_off_simple(scf):
def move_linear_simple(scf):
time.sleep(1)
mc.forward(0.5)
time.sleep(1)
mc.back(0.5)
time.sleep(1)
If you replace take_off_simple(scf) in __main__ with move_linear_simple(scf), try to run the script.
You will see the crazyflie take off, fly 0.5 m forward, fly backwards and land again.
Now we are going to add a turn into it. Replace the content under motion commander in move_linear_simple(..) with the following:
time.sleep(1)
mc.forward(0.5)
time.sleep(1)
mc.turn_left(180)
time.sleep(1)
mc.forward(0.5)
time.sleep(1)
Try to run the script again. Now you can see the crazyflie take off, go forward, turn 180 degrees and go forward again to its initial position. The mc.back() needed to be replaced with the forward since the motion commander sends the velocity setpoints in the body fixed coordinate system. This means that the commands forward will go forward to wherever the current heading (the front) of the crazyflie points to.
Double check if your code is still correct:
import logging
import sys
import time
import cflib.crtp
time.sleep(1)
mc.forward(0.5)
time.sleep(1)
mc.turn_left(180)
time.sleep(1)
mc.forward(0.5)
time.sleep(1)
cb=param_deck_flow)
time.sleep(1)
sys.exit(1)
# Arm the Crazyflie
time.sleep(1.0)
Step 4: Logging while flying
When the motion commander commands have been executed, the script stops and the crazyflie lands… however that is a bit boring. Maybe you would like for it to keep flying and responding certain elements in the mean time!
Let’s integrate some logging to this as well. Add the following log config right into __main__ under SyncCrazyflie
logconf = LogConfig(name='Position', period_in_ms=10)
logconf.add_variable('stateEstimate.x', 'float')
logconf.add_variable('stateEstimate.y', 'float')
scf.cf.log.add_config(logconf)
logconf.data_received_cb.add_callback(log_pos_callback)
sys.exit(1)
logconf.start()
logconf.stop()
Don’t forget to add from cflib.crazyflie.log import LogConfig at the imports (we don’t need the sync logger since we are going to use the callback). Make the function log_pos_callback above param_deck_flow:
def log_pos_callback(timestamp, data, logconf):
print(data)
NOW: Make global variable which is a list called position_estimate and fill this in in the logging callback function with the x and y position. The data is a dict structure.
Just double check that everything has been implemented correctly and then run the script. You will see the same behavior as with the previous step but then with the position estimated printed at the same time.
You can replace the print function in the callback with a plotter if you would like to try that out, like with the python lib matplotlib :)
import logging
import sys
import time
import cflib.crtp
position_estimate = [0, 0]
time.sleep(1)
mc.forward(0.5)
time.sleep(1)
mc.turn_left(180)
time.sleep(1)
mc.forward(0.5)
time.sleep(1)
print(data)
global position_estimate
position_estimate[0] = data['stateEstimate.x']
position_estimate[1] = data['stateEstimate.y']
cb=param_deck_flow)
time.sleep(1)
sys.exit(1)
# Arm the Crazyflie
time.sleep(1.0)
logconf.start()
logconf.stop()
Step 5: Combine logging and motion commander
There is a reason why we put the position_estimate to catch the positions from the log, since we would like to now do something with it!
Back and forth with limits
Lets start with a new function above move_linear_simple(scf):
def move_box_limit(scf):
while (1):
time.sleep(0.1)
If you would run this (don’t forget to replace move_linear_simple() in __main__), you see the crazyflie take off but it will stay in the air. A keyboard interrupt (ctrl+c) will stop the script and make the crazyflie land again.
Now we will add some behavior in the while loop:
mc.start_forward()
while (1):
if position_estimate[0] > BOX_LIMIT:
mc.start_back()
elif position_estimate[0] < -BOX_LIMIT:
mc.start_forward()
time.sleep(0.1)
Add BOX_LIMIT = 0.5 underneath the definition of the DEFAULT_HEIGHT = 0.5.
Run the script and you will see that the crazyflie will start moving back and forth until you hit ctrl+c. It changes its command based on the logging input, which is the state estimate x and y position. Once it indicates that it reached the border of the ‘virtual’ limit, it will change it’s direction.
You probably also noticed that we are using mc.start_back() and mc.start_forward() instead of the mc.forward(0.5) and mc.back(0.5) used in the previous steps. The main difference is that the mc.forward and mc.back are blocking functions that won’t continue the code until the distance has been reached. The mc.start_…() will start the crazyflie in a direction and will not stop until the mc.stop() is given, which is done automatically when the motion commander instance is exited. That is why these are nice functions to use in reactive scenarios like this.
import logging
import sys
import time
import cflib.crtp
BOX_LIMIT = 0.5
while (1):
mc.start_back()
mc.start_forward()
cb=param_deck_flow)
time.sleep(1)
sys.exit(1)
# Arm the Crazyflie
time.sleep(1.0)
logconf.start()
move_box_limit(scf)
logconf.stop()
Bouncing in a bounding box
Let’s take it up a notch! Replace the content in the while loop with the following:
body_x_cmd = 0.2
body_y_cmd = 0.1
max_vel = 0.2
while (1):
body_x_cmd=-max_vel
body_x_cmd=max_vel
if position_estimate[1] > BOX_LIMIT:
body_y_cmd=-max_vel
elif position_estimate[1] < -BOX_LIMIT:
body_y_cmd=max_vel
mc.start_linear_motion(body_x_cmd, body_y_cmd, 0)
time.sleep(0.1)
This will now start a linear motion into a certain direction, and makes the Crazyflie bounce around in a virtual box of which the size is indicated by ‘BOX_LIMIT’. So before you fly make sure that you pick a box_limit small enough so that it able to fit in your flying area.
Note: if you are using the flow deck, it might be that the orientation of this box will seem to change. This is due to that the flow deck is not able to provide an absolute heading estimate, which will be only based on gyroscope measurements. This will drift over time, which is accelerated if you incorporate many turns in your application. There are also reports that happens quickly when the crazyflie is still on the ground. This should not happen with MoCap or the lighthouse deck.
Check out if your code still matches the full code and run the script!
import logging
import sys
import time
import cflib.crtp
BOX_LIMIT = 0.5
body_x_cmd = 0.2
body_y_cmd = 0.1
max_vel = 0.2
while (1):
#if position_estimate[0] > BOX_LIMIT:
# mc.start_back()
#elif position_estimate[0] < -BOX_LIMIT:
# mc.start_forward()
body_x_cmd = -max_vel
body_x_cmd = max_vel
body_y_cmd = -max_vel
body_y_cmd = max_vel
time.sleep(0.1)
print(data)
print(value)
if value:
else:
cb=param_deck_flow)
time.sleep(1)
sys.exit(1)
# Arm the Crazyflie
time.sleep(1.0)
logconf.start()
move_box_limit(scf)
logconf.stop()
You’re done! The full code of this tutorial can be found in the example/step-by-step/ folder.
What is next ?
Now you are able to send velocity commands to the Crazyflie and react upon logging and parameters variables, so one step closer to writing your own application with the Crazyflie python library! Check out the motion_commander_demo.py in the example folder of the cflib if you would like to see what the commander can do.
