Build and flash instructions
Mind that these instructions are only for the Crazyradio PA, and not for the Crazyradio 2.0.
Building the firmware
Requirement:
  • SDCC
  • Binutils (needs objcopy)
On Ubuntu this can be installed with:
sudo apt-get install sdcc binutils
On Mac (using homebrew):
brew install sdcc
brew install binutils
ln -s /usr/local/bin/gobjcopy /usr/local/bin/objcopy
To build the firmware you should navigate to the firmware directory.
Build for Crazyradio
make CRPA=0
Build for Crazyradio PA
make CRPA=1
Flashing the Firmware
To flash the firmware run the following from the firmware directory:
python ../usbtools/launchBootloader.py
sudo python ../usbtools/nrfbootload.py flash bin/cradio.bin
After flashing successfully, you need to replug the Crazyradio. More details are in the wiki.
Check your firmware version
Run the following command:
lsusb -d 1915:7777 -v | grep bcdDevice
