BigQuad deck
This product is in the Early Access stage.
BigQuad deck
Go big!
Build a quadcopter the size you need, while still running the same code.
How it works
With the BigQuad deck you can transform your Crazyflie 2.x to a bigger quad by connecting external Electronic speed controllers (ESCs) to the breakout connectors on the deck. The autodetection of the deck makes this transformation possible to do in seconds. The deck also contains breakout header connectors for additional accessories such as external receiver (CPPM input) and GPS. It can also monitor battery voltage and current.
Specifications
Features
  • 4 x ESC connectors
    • CPPM input (3 pin)
    • GPS input (4 pin)
    • I2C expansion (4 pin)
    • Buzzer output (2 pin)
Mechanical specifications
  • Weight: 3.8g
  • Size (WxHxD): 36x40x5mm
  • M3 mounting holes placed 30.5mm square
  • Designed for mounting above or under the Crazyflie 2.X
Mechanical drawing
Electrical specification
  • Power Crazyflie 2.X with 4.5V - 5.5V from ESC
  • BiqQuad deck inputs are 5V tolerant
  • Battery voltage monitoring divider scaled for input up to 23V
  • Current monitoring input 0V - 3V
  • BiqQuad deck and Crazyflie 2.X current consumption:
    • ~120mA without any additional decks
    • Up to 500mA if Crazyflie 2.X battery is connected and charging
Pinout
Connector Pin Signal
GPS 1 GND
GPS 2 5V
GPS 3 TX
GPS 4 RX
I2C 1 GND
I2C 2 5V
I2C 3 SDA
I2C 4 SCL
CPPM 1 GND
CPPM 2 5V
CPPM 3 signal
MON 1 GND
MON 2 VBAT
MON 3 current
Usage
Caution
Assembly
Currently there is only a basic setup but as the development advances so will the documentation. Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below. Note that the 5V is needed for the motor signals and is not optional.
Basic connection diagram
ESC basic setup
Basic connection picture
Bigquad basic connection
Attaching the Crazyflie 2.0
Crazyflie with bigquad deck
Building Firmware
Enable BigQuad features
Make sure to have the crazyflie-firmware code updated to a later version then this commit. Then define the flag ENABLE_BQ_DECK, preferably in the config.mk file add:
CFLAGS += -DENABLE_BQ_DECK
Early access notes (2021)
  • When the BQ-Deck is detected it will automatically switch to brushless motor drivers. It will be noted in the cfclient console if it is detected or not.
  • External battery voltage/current reading is implemented but no logic behind it, so don’t run out of battery. * You can connect the cable (MON port) and watch the log variable.
  • The PWM output is set to 400Hz. Use ESCs which can handle this or compile with new value. There is also the possibility to enable OneShot125 output.
Development
Errata
Compatibility with Loco deck, microSD and Flow (v2) deck
The Loco deck, microSD and Flow (v2) deck all uses the SPI bus. As the BigQuad deck uses the deck SPI buss pins for possible voltage and current measurement, and they are multiplexed with analog input, the BigQuad deck is not out-of-the-box compatible with these decks.
To work around this issue do the following:
  • By removing capacitor C1 on the BigQuad deck (only valid for Rev C, Rev C1 already has this capacitor removed) bigquaddeck-remove-c1.png
  • Not having BQ_DECK_ENABLE_PM defined.
  • Disabling the extRx functionality by commenting out extRxInit() in bigquad.c
To make it work with the Flow (v2) deck more changes/patching are needed:
  • The Flow HW ChipSelect (IO3) interfere with BigQuad PWM and needs to be moved. Cut trace and solder patch on Flow deck from IO3 to IO1.
  • Change the CS pin in flowdeck_v1v2.c (IO3 → IO1)
Next problem is how to mount the deck in a nice way on the quad, we leave that up to you.
