Absolute position
How it works
The Loco Positioning deck is a Tag in a Loco Positioning system and measures the distances to Anchors. The distances are used to estimate the absolute position of the Crazyflie 2.x in the room, which can be used for autonomous flight. The position is calculated on-board of the Crazyflie and there is no need for an external computer for position estimation.
Read more about the Loco Positioning system
This product is intended to be used together with Loco Positioning Nodes and can not be used standalone.
Specifications
Features
- Measures distances to Loco Positioning Node Anchors
- 4 status LEDs
Mechanical specifications
- Weight: 3.3 g
- Size (WxHxD): 28x35x4 mm
- Designed for mounting above or under the Crazyflie 2.X
Electrical specification
- Based on the Decawave DWM1000 module
- Implements IEEE 802.15.4 UWB
- 1-wire memory for automatic expansion deck detection
- Max 150 mA consumed, depends on operation mode and configuration
- Crazyflie 2.X flight time with deck 6 minutes
Radio specification
- Operates at 3.2 - 7 GHz
- Channel bandwidth 500 MHz
Ranging specification
- Ranging accuracy ±10 cm according to DWM1000 spec
- Maximum tested range 10 m
- Ranging rate 500 Hz, shared over all anchors. Around 80Hz per anchor with 6 anchors
Compatibility
Usage
Go to the Loco positioning system tutorial to set the loco positioning up. Afterwards, you can try out the loco positioning based flight tutorial. Also for more general information over how the loco positioning system fits in our eco system, go to Positioning Systems Overview.
Development
Implementation Firmware
All the Loco positioning is estimated onboard of the crazyflie. Go the the technical documentation of the loco positioning system of how it is implemented into the Crazyflie Firmware and the Loco positioning node firmware
It is important to have a good feel for the stabilizer module of the crazyflie, in particular state estimation with the Extended Kalman Filter
- Loco Positioning system
- Start here
- Development overview
- FAQ
- Getting help
- Expansion decks of the Crazyflie 2.x
- Datasheet
- Schematics
