Increased flight time and thrust
How it works
With a new and improved design these propellers gives the Crazyflie a boost in efficiency. Both flight time and maximum thrust is increased with up to 15%! The design is available in two colors, black and green.
Note: This propeller is not the stock propeller delivered with the Crazyflie 2.1
Specifications
Mechanical specifications
- Diameter: 47 mm
- Pitch: 17 mm
- Fits shaft: 0.8 mm
- Material: PC
- Weight: 0.3 g
- Number of blades: 2
Usage
Mount the new propellers on your Crazyflie and enjoy the increased flight time and thrust!
When mounting the propellers please note the following:
- The propeller 47-17 should rotate CCW (mount on M1 and M3)
- The propeller 47-17R should rotate CW (mount on M2 and M4)
